I used to be able to run my refrigerator on the batteries for about a day and a half before I had to worry about recharging. But, lately I've noticed the voltage dropping below 12 volts with the refrigerator running. I chalked it up to my old mismatched batteries finally wearing out, so I sprung for a new set and installed them over the weekend. After charging overnight, we went for a sail and after a couple of hours the voltage was again reading below 12 volts (I don't recall the amps, but don't think they were excessive). Turning off the refrigerator brought the voltage back up to around 12.8 volts.
My assumption is that I must have some corroded connections in the system and I will chase them down this weekend. I've looked online for suggestions, but can't seem to find anything that addresses these symptoms. Am I on the right track to suspect corroded connections? How much of a voltage drop is normal when running loads like a refrigerator?
