I have been asked numerous times what the rules are about protecting battery terminals and how I do this. A lot of my images do not show them because I may be trying to show physical wiring connections.
#1 If the battery is in its own dedicated compartment, separated from the rest of the vessel, this compartment can count as your terminal protection.
#2 If your batteries are in protective battery boxes, with lids, this can count as your terminal protection.
#3 If the batteries are not in a dedicated locker or do not have battery boxes, AGM's don't require acid containment, then you should protect the terminals with "terminal hats", as I call them, "cable caps" or "terminal boots" as they are most often refereed to.
To most boaters this would be a good complete battery installation. It is not;
For batteries with this type of bolt terminal I use this type of terminal hat:
This is how they come out of the package:
One trick I do is to slit the bottom side so the hats can be taken on/off without needed to fit them over the cable ends. Most cable hat makers have totally forgotten that adhesive shrink wrap makes the cables bigger near the terminal thus a terminal hat for 2/0 wire does not slide over 2/0 wire once properly sealed.
For series or parallel wiring fit the hat and then mark where the series or parallel cable will exit the hat. Make two slits the width of the cable:
The exit flap you just made creates an excellent place for another wire tie:
An installation is not complete until the battery is well secured, acid containment is in place (for flooded batteries), cables are labeled, cables are well secured, terminals use locking washers or nyloc nuts & the terminals are protected via numbers 1-3 above.
This bank is in its own dedicated battery compartment thus it is not required to use terminal hats. You can always add them, if you wish, for additional protection.
If you are utilizing MRBF fuses, and lack sufficient stud length for good cap grip, I find it best to physically wire tie the hat onto the fuse.
Not all terminal hats will work for all batteries so choose what works best for your banks.. On this boat (negatives disconnected & secured for winter storage) you can see that the start battery uses one type of hat and the 4D battery utilizes another type.
Note: I usually use 1" or 1.5" river raft / kayak straps (source NRS) for battery hold downs and stainless steel footman's loops by Hayn or Suncor for securing the batteries in place. I do not and will not use plastic footman's loops or the cheesy straps that come with plastic battery boxes.
