I Have A 2006 Hunter 28. With My Diesel Engine Running Is It "safe"
To Change The Battery Switch Between The 1, Both And 2 Settings?
Should be perfectly fine. Just don't pass through off. If you want to test you switch for wear, turn on cabin lights and rotate through 1/2/BOTH, you should see no flicker....I Have A 2006 Hunter 28. With My Diesel Engine Running Is It "safe"
