Battery Switch Question ?
733
Hunter 30 Vero Beach
After analyzing my electrical system, I've come to the realization that my batteries aren't wired the way they should be, or the way I want them.
The way it is........ I have a Perko battery selector switch with 3 terminals on the back. (#1-#2- Common) If my battery switch is on #1 the power for the starter and the house bank will draw off of the starter battery. If I switch it to both the starter and house draw off of both. If I switch it to #2 the starter and house draw off of the house bank. Shouldn't the batteries be wired up so that one powers the starter and the other powers the house. and if so, how would I wire that without buying another battery selector switch? Another question would be......How would I get both batteries to charge if they are separated? The battery selector switch isn't original, so I'm think the PO had all of the wiring wrong, but I can't seem to find the right way to wire it up. I've looked in Nigel Calder's and Don Casey's books but I can't seem to find a wiring diagram that lays it out this way. Am I wrong to want my batteries hooked up like this?
Dave
Feb 6, 1998
11,703
Dave
Dave,
It is perfectly fine the way it is. There is little to no need on a small sailboat with small aux diesel to need a dedicated "starting" battery. I have started all my engines, for a long, long time on my house banks. I use a 1/2/BOTH/OFF switch on my own boat and only ever use position #1 (house) and OFF. Position #2 (reserve bank) and BOTH are for an emergency only. I don't think in terms of a start and house I think in terms of a reserve and house.
The 1/2/BOTH/OFF switch is a very useful device and there are a few small changes that you can make that will make it even better. Please do keep the 1/2/BOTH/OFF. Everything you need for a very simple and redundant system is already there and there is no need to spend more money on new switches or drill yet more holes in your boat over what you already have.
Simply make your house bank #1, ,or "primary" and the start/emergency battery #2 or "back up/secondary". #2 as a secondary battery, for me, is always easy to remember but this is just a personal preference.
When you get to the boat simply switch to bank 1. When you leave the boat simply switch to OFF. You'll use the house batts for everything.. By doing this you'll only ever need to use position #1/House yet your emergency (start) bank will always be sufficiently charged if and when it is needed if you've also upgraded to an Echo or ACR type charging device. The charging of the start bank can all be done behind the scenes and is automatic by adding an ACR or Echo type charger. Doing this avoids the large "human error" factor of memory lapses.
What happens if I kill my house bank?
If you kill a bank don't fall into the trap of combining the dead bank with a perfectly good one by using the BOTH feature. Simply switch to the second fully charged reserve bank when you need to. Combining a good bank with a dead bank only bleeds off precious cranking amps from the good battery.
Can my house bank really start my engine?
YES!! If you are practicing good battery management and never discharging the house bank below 50% state of charge you should always be able to start your engine just fine using the house bank and will only ever use the battery switch when you get to the boat to flip it to position #1/House. When you leave turn it to OFF. I have three group 29/31 batteries on my vessel. Even though they are deep cycle they still produce a combined MCA (marine cranking amp) rating of well over 3000 amps at about 65 degrees F. My single group 31 reserve battery, in comparison, only has 1000 MCA.
It takes VERY LITTLE from your bank to start a small diesel. In fact I can not even measure .1 Ah of consumption from a 240 Ah bank, using a Xantrex Link Pro when I start my 44HP four cylinder diesel.
Starting the engine requires very, very little from a battery, many folks over think this and believe it requires a lot more than it really does. The peak in-rush current draw, for a split second, on my 44HP four cylinder Westerbeke is about 160 amps (peak split second current). The starter motor on my Westerbeke is a 1.5 kW an the starters on the average Universal M-25's are .8 kW.
The 1/2/ALL/OFF switch is a great device, if wired appropriately. When wired in the fashion most builders do, it sucks and thus gets a bad rap.
The 1/2/ALL/OFF switch retains all the original features & benefits yet looses the frying of diodes and the switching back and forth if you wire the alt direct to house and use an ACR, Echo type charger to top off the start bank.
For instance if your ACR or Echo Charger failed, which could happen, you can always use the ALL/BOTH feature to charge both banks from the alt just as you always did. No repairs or jumper wires just flip the switch to ALL, for charging, and you're back in business.. You will not however fry the alternator diodes because it always has a load on it by wiring directly to the house bank.
It is a good idea to add a fuse/breaker within 7" of the battery for the direct feed alt wire. It is also a good idea to fuse your banks.
As always there is no one right way to wire banks, unless you do it dangerously, but on small boats it makes little sense to ditch a perfectly good 1/2ALL/OFF when a simple re-wire will give you everything you need with simplicity and total redundancy should a combiner fail..
#1 Assign house bank to batt switch position #1
#2 Install reserve battery to position #2
#3 Wire alternator output directly to the house bank with sufficient size cable & fuse.
#4 Install ACR or Echo Charger between banks.
#5 Use boat in position #1 for starting AND house loads. Switch to OFF when you leave it's that simple.
So why do I want to wire my alt direct to the house bank??
I prefer to feed the alt directly to the house bank and not the reserve bank as the start bank is for back up or emergency, in this situation, and would usually be at or near 100% SOC anyway.
1- No more worries about fried diodes.
2- Accurate voltage sensing & less chance of voltage drop over factory wiring.
3- If you use an Echo Charger you need to do this anyway
You should NOT however wire the alt directly to the house battery unless you have either a VSR/ACR (voltage sensitive relay/ automatic charging relay) or a unit like the Echo Charger or Balmar Duo Charger.
Follow me on this one.
If you sense/wire directly to the house bank, bank 1, but do not have an ACR or Echo type unit installed, this means you could physically select the battery being used via the 1/2/BOTH/OFF switch.
If you select bank two as your source and the alt is connected to bank 1 you will draw down bank two and not replenish it unless the ALL function is selected during charging. In short, without an ACR or Echo type charger I would not wire directly to the house bank and instead would leave it wired through the common post of the battery switch.
With an ACR/Echo you can still select bank 2 but it will automatically be getting charged via the combiner or Echo even with the house bank being direct wired...
So what is a battery combiner / ACR / VSR??
Blue Sea ACR Si Series (LINK)
An ACR is an automatic charging relay or as I like to describe it an automated "BOTH" switch. All an ACR does is parallel or isolate the two banks based on voltage, hence the term VSR which just means "voltage sensing relay".
The term "ACR" is Blue Sea Systems trade name. A VSR is essentially a high current automated relay that senses voltage and combines banks when the voltage rises.
With the Blue Sea ACR if it senses 13.6 volts for more than 30 seconds it combines or parallels the banks. If it senses more than 13.0 volts for a period of two minutes, it also combines or parallels the banks.
When an Blue Sea ACR senses a drop in voltage below roughly 12.35V, for more than 10 seconds, it opens or disconnects. It will also open when it sense 12.75V or less for more than 30 seconds.
Combiners, VSR's, ACR's or what ever you prefer to call them, are very simple and fully automatic requiring no human intervention at the battery switch. Truly a "set it and forget it" device..:)
VSR's, unlike antiquated diode isolators, can work with any charge source you desire. When voltage begins to rise, from solar, wind, alternator or shore charger the VSR/ACR's logic automatically energizes the relay coil, closes it, and combines/parallels the banks for charging. Electrically speaking this is no different than if you flipped the 1/2/BOTH/OFF to BOTH in order to charge both banks.
The best feature of a combiner is that it never forgets to parallel when charging is present or isolate/disconnect the banks when a charge source is not present. When the batteries are not seeing a charge source they are fully isolated or disconnected from one another.
These devices are relatively inexpensive $65.00 - $150.00 depending upon model and amperage. They are also very easy to wire. The Blue Seas ACR has three wires to connect, ground and house and start bank jumpers. Yandina also makes a battery combiner/VSR.
If you wire a VSR properly, meaning all charge sources are wired to directly charge the house bank, then you can get away with a much smaller amperage VSR. The smallest Blue Sea ACR is rated at 65A and is plenty for charging a starting battery, if all charge source already feed to the house bank. The little Blue Sea m-Series 65A ACR runs about $59.00 and is a tremendous value.
The unit labeled ACR is a Blue Seas ACR:
So what is an Echo Charger or Battery to Battery Charger?
Xantrex Echo Charger (LINK)
The Xantrex Echo Charger belogs to a family fo charge management devices called DC to DC chargers or Battery to Battery chargers (B2B's). The Echo Charger is essentially an electronic 12v to 12v charger. B2B chargers like the Echo Charger do not technically combine/parallel the banks and are single direction chargers. The banks remain isolated and current can only pass from the house bank to the start bank. It simply takes or "bleeds" it's power from the charge source or the house bank and when it senses over 13.0 volts energizes and begins charging the reserve bank. When it sense below 13.0 volts it turns charging off. It can supply up to 15 amps of charge current to the reserve battery while borrowing/bleeding it from the house bank. Normally that battery will be at or near full and you'll rarely ever see it pull more than an amp or two anyway so 98% of the time your alts full output heads directly to the house bank. The Echo Charger is also a voltage follower and will follow the incoming voltage to the house bank. When the house goes into float mode so does the reserve bank.
The Echo Charger is also a simple three wire hook up but needs to feed the reserve bank, and pull from the house bank. All charge sources should be fed to the house bank, solar, alternator, wind and shore side charger.
This is an Echo Charger:
The Balmar Duo Charger is similar to the Echo, and a bit more expensive and can supply up to 30 amps of charge current.
By simply adding an ACR or Echo Charger, you can still go to your boat and select HOUSE and when you leave select OFF. That's it, simple. The charging of the start bank is taken care of behind the scenes.
Voltage Brown-Out's:
Some folks complain of voltage drop out for electronics when starting off the house bank. I don't experienced this in any of my installations. I can start the engines and not reset any of the electronics even down to about 35-40% state of charge, in a properly sized & wired system.
If drop out is occurring then there are really only a few scenarios that cause this.
#1 Your batteries may be ready for replacement
#2 Your wiring is undersized
#3 Your system is wired incorrectly
#4 You have some bad connections.
#5 Your bank is simply too small
To avoid drop-outs you can start the motor, then flip on the instruments.
You can also choose to direct wire a dedicated starting battery but it will be more complicated if you want to retain the ability to start off the house bank in an emergency. This is why the 1/2/BOTH/OFF is such a good tool despite it often beingbadly maligned.
P.S. I edited the title so you hopefully get more responses...
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
Maine Sail, fantastic!! Truly, you know your stuff. Thanks! One question: are your batteries true "deep cycle", or are they dual purpose?
Also, on my motor boat I carry one of those jump starter things - saved my butt once, and someone else's another time. Cost was no more than $100. Great investment, at least for me, just in case.
Feb 6, 1998
11,703
They are "labeled" as "Deep Cycle" but they are really NOT a deep cycle battery like a golf cart battery or sweeper scrubber battery would be. They are rated at 125 Ah (20 hour rate) and 875 MCA (@32F). They produce over 1000 MCA when tested at room temp, which is a close approximation to summers in Maine..
On 5/9 of this year I tested my batteries, this is their fourth season, against brand new ones off the shelf. They tested within a smidgen of brand new using a Midtronics impedance tester. (Impedance testers DO NOT accurately represent the 20 hour capacity just cranking ability)
Remember, when you parallel 12V batteries the cranking capacity doubles and this includes your cranking amps. Even West Marines largest true starting battery, in this size range, a group 27, only produces 1050 MCA at 32F. Because house banks are typically much larger you have more available cranking amps in your house bank that you would in a dedicated starting battery.
Even a pair of West Marine/Deka Sea Volt GC2 6V batteries wired ins series for 12V produces 975 MCA which is only 75 MCA less than their comparable case size group 27 starting battery. This is considerably more than is required to start any of our small diesels. Two WM 6V batts in series will give you 975 MCA and four in series parallel will give you 1950 MCA @32F. How often are you starting the engine at 32F...
Westerbeke, the manufacturer of our engine, requires a battery that can deliver 400 cranking amps. I have 3000+ available with my house bank.....:)
dugout
Nov 15, 2008
40
Pearson P33 Maryland's Famous Eastern Shore
The Balmar Duo Charger is similar to the Echo but more expensive and can supply up to 30 amps of charge current. It does have a few flaws so I'd stick with the Echo or ACR.
MS;
What issue did you have with the Balmar Combiner? I have one and got it due to the temp sensing feature. I've boiled start batteries with other combiners.
What do you feel is a reasonable fuse size for a start circuit with a 1kw starter on a 2GM20F. Would 200 handle it?
Thanks for you thoughtful and educational posts!
Mar 22, 2004
733
Thanks Mainsail,
That's what I was looking for. I did find a diagram in one of Nigel Calder's books that matches what you are talking about minus the echo charger and ACR. If I have a Xantrex Truecharge 20, is it as good as the Echo charger, and if my Truecharge 20 isn't working properly, should I replace it with the Echo charger and ACR or stay with the newer Truecharge 20 version? Also, I would like to keep my old house bank,(2 golf cart batteries) it still is maintaining an 80% charge. I would like to buy a new reserve battery bank (2 group 27's). With the Xantrex Truecharge able two charge more than one bank at a time, can I do this or should I buy all new batteries? Money is tight here right now, and I'm looking to do this right, but as reasonably priced as possible.
Thanks,
Dave
P.S. no worries on the title
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Mainesail - as always thanks for good detailed advice.
I ran across just such an installation (alternator to house bank, echo charger to start bank) this spring when I was helping install a new Yanmar on the boat of a world-cruising couple. They couldn't immediately give me a wiring diagram, and since I'd never seen that configuration before, it took a while before I understood it (and confirmed that it was indeed wired that way), but now I like it and I agree that it's likely the best overall arrangement.
To Nereussailor's point about seeking a clear drawing, I have the Calder book (3rd ed.), and around pages 40 to 60 there are some good basic battery configuration circuit drawings, and here is the Xantrex Echo charger manual, otherwise I agree with him that there doesn't seem to be alot of good published drawings around that clearly show the alt/batteries/bank sw/echo charger circuit in a clean, easy-to-understand format. Mainesail - do you have a circuit drawing of your engine/battery/charging setup you could share?
Jul 28, 2010
914
Maine Sail, do you have, or do you recommend having, both a VSR and an Echo type charger? They seem to do about the same thing, but in slightly different ways.
Can't you just set it on BOTH and forget it?
Jul 29, 2010
29
Irwin 25 NC
Maine saill,
Enjoy all of your posts on several forums...quick question please sir.
Based on your experience what brand/type deep cells do you use or would recommend looking into?
(I hope this is within the relm of on-topic)....thanks
Not quite, kenn.
We've had so many discussions of this on this board that it almost has become repetitious, although for newcomers, it's, well, new to them!:)
Reply #11 on this link explains the whole 1-2-B switch issue, and also includes a very important link to a discussion Maine Sail and I had on the C310 forum right here on co.com, and is complimentary to Maine Sail's earlier post on this topic, and discusses combiners vs. echo chargers, so I encourage you to click on those links and read 'em, too:
http://c34.org/bbs/index.php/topic,4949.0.html
Combiners are non-current limiting, so if you motor a lot there is the possibility of overcharging the reserve bank, which is why the current limiting echo charger is better for a big house/small reserve bank arrangement.
Reply #12 has exactly the simple diagram you're looking for:
Reply #23, here, has a more complicated diagram that I worked up for my boat: http://c34.org/bbs/index.php/topic,4623.15.html
Other than a dual ground wire back to the engine ground, it's exactly the same, electrically, as the simple diagram that Dave produced in the link above.
Feb 6, 1998
11,703
MS;
If the battery it is charging needs or can accept more than 30 amps the unit shuts down, pauses and tries to re-boot, repeat, repeat, repeat. It is however extremely rare that any start battery would take 30A for longer than it takes the Duo Charge to time out. I have had lengthy discussion with Balmar about this but as of yet the problem has not been addressed because, as they say, it is for charging starting batteries and for that purpose it works amazingly well.. This is rarely if ever a problem on a sailboat, using the method I outlined above, unless you need to use your reserve bank for more than just an occasional start.
The fuse is always sized for the wire it is protecting and also to the AIC (Amperes Interrupt Current) for what the batteries can supply, based on CCA rating of the bank.
If your wire can't take a 200 amp fuse then you'll need to go smaller. The AIC rating is the amount of current your batteries could supply if shorted.
Keep in mind that ANL fuses can far exceed their "rating" for short duration's before blowing. A 200 A ANL can do about 5 seconds at 200% of it's rating and up to 500 seconds at about 150% of its rating. ANL (LINK) If you blow a 200 amp ANL on a 2 GM you likely have other issues. Again, my four cylinder 44HP Westerbeke can pulls only about 640A but only for a fraction of a second during the in-rush period.. My ANL at half that has been fine for many hundreds of starts.
For typical house banks you'll want fuses with a 5000 AIC or more depending upon the CCA of the entire bank. The only fuses that really meet the ABYC's AIC requirements for house bank fusing are ANL, MRBF and Class-T.
This is a good chart to show various AIC ratings:
Nope. One or the other, not both. You need to understand the purpose: they are simple relays that close when charging voltage is present, from any source. It's a simple "automatic switch" that allows current to flow into the reserve bank without you doing anything (other than wiring it up, of course).
Feb 6, 1998
11,703
Can't use both, it is one type or the other. They do, do things in slightly different ways, and this is another discussion that can get complicated. Both work well on wet cells but I don't personally like ACR type units on AGM's due to the very high discharge and acceptance rates of these batteries.
If you have wet cells use either unit.
Feb 6, 1998
11,703
Stu,
I would certainly classify the ACR as a simple relay. According to Xantrex tech support, who knowing them could be wrong, the Echo is not really a "simple relay" like a combiner/ACR it is more of a DC - DC electronic charger. It has an internal voltage sensing chip that turns the unit on at 13v but no two way combining type "relay" like an ACR has. This device only works in one direction and does not combine banks. I think that is the most important distinction between the two products. Where a combining relay/ACR works equally as well in both directions the Echo only works in one direction.
It is critically important to remember that this device only works passing current from the house bank to the reserve/start bank. ALL charge sources MUST be led to the house bank other wise the unit will not work correctly. Leading the alt to the common post of the batt switch can make it not work at all when the start battery is selected via the switch. Unfortunately this is NOT made very clear in the manual. I have been asking Xantrex to change this now for well over a year and a half but.....
Thanks Mainsail,
Dave,
I think you have a serious misunderstanding here. The Truecharge 20 is a battery charger which works from shorepower to charge your batteries. The echo charger is a completely different piece of equipment, it is NOT a charger, it is a way to automatically "bleed" off charging current, whether from a shorepower charger or any other charging source (solar, alternator, etc.) to your reserve bank.
Please re read Maine Sail's descriptions and the links I have provided. You need to get your head around the differences and understand the terms and the equipment before you go any further.
Feb 6, 1998
11,703
I have known far to many boaters who have been stranded by accidentally leaving the switch set to BOTH and killing both banks.
I have also seen and fixed far to many alternators with blown diodes caused by needless switching of the battery switch by accidentally passing through OFF with the motor running and a load on. Just happened to a guy at the club last week.
Of course it is quite often the boater who knows the least about batteries that does this, kills both banks, and this is all the more reason to simplify and remove the possibility for human error with a simple device like an ACR or Echo Charger.
Jul 28, 2010
914
I have also seen and fixed far to many alts fried by needless switching of the battery switch by accidentally passing through OFF with the motor running and a load on. Just happened to a guy at the club last week.
Maine Sail, why is that? Is it because the alternator was still putting out with nothing for it to go to? Or was something drawing power with no battery, therefore trying to draw directly from the alternator?
Feb 6, 1998
11,703
When an alternator has a load on it, and it is suddenly disconnected from the load (open circuited), the alternator will suffer an internal voltage spike which can and very often does fry the diodes. This then requiring an alternator re-build.
If the alternator is wired to the "C" post (common post) of the battery switch, which is far too common, the "voltage transient" cause by open circuiting the alternator will feed the entire DC system and can quite often blow electronics, TV's, plotters depth sounders autopilots or any other sensitive devices turned on at the time, not just the alternator. This is a very "under discussed" topic that happens with far too much regularity.
It All Depends on How It's Wired
Guys, we've said it before, and we'll say it again:
PLEASE, puleeze, read the links that Maine Sail and I keep providing you.
IF the AO is wired to the C post of the 1-2-B switch, you could fry your diodes.
If the AO goes to the house bank, the switch can even be turned off.
This is discussed in detail in the link I provided earlier.
Go read the links, you'll find the answers there.
Putting a 1-2-B switch on BOTH makes no sense, because all you'll do is draw a good bank down to the level of the bad bank. The link discussed why boats were incorrectly wired by builders and MS discussed it above.
Read first, then ask away.
Please.
