Battery Switch Operation for Catalina 30s
BATTERY SWITCH
· Most Catalina 30 sailboats have 2 batteries on board which are isolated from each other. (Note: A third battery can also be wired into the house bank to extend amp hours. If this is the case, the battery switch for the house bank is used for both batteries on the house bank if the switch only has a 1 and 2 position.)
· Battery #1 (if wired as the starting battery) is used for starting the engine.
· Battery #2 (if wired as the house bank) is used to run the boats electrical system such as interior lights, navigation equipment, running lights, refrigeration, etc. (Note: If wired with 1 as house bank and 2 as starting, then change the battery designations for this writeup).
· Battery switch has the following positions: 1, 2, All, Off.
· When sailing, keep this switch in position #2 if 2 is the house battery so battery #2 only is being used to run the electrical system. This way if the battery runs down you can still start the engine by switching to battery #1.
When starting the engine the All Position will provide greater starting power.
· When running the engine you can select which battery to charge by using the battery switch. In position 1 or 2 you will charge only the battery selected. In the “All” position both batteries are charged. In “Off” position neither is charged.
· Recharge Battery #2 frequently since electrical system can easily drain a battery. Batteries should never be discharged past 50% to insure longer battery life. With diesel engines, battery #1 requires less charging since it is only used to start the engine and will only slightly discharge the battery. Gasoline engines require a constant power source so it is better keep the switch in the “All position” while motoring to insure both batteries remain charged.
· Be careful to insure the battery switch is not left in the “All” position while sailing since this will run down both batteries and you may not be able to start the engine. Always check the switch position whenever the engine is shut down and the vessel begins sailing.
· The battery switch is bypassed while charging on shore power so both batteries are charged regardless of switch position.
· Avoid changing battery switch position to off while the engine is running as this can damage the alternator.
Note: This post was entered under the Cat 30 Forum and was intended for the Catalina 30 only and does not apply to every sailboat. It has been my experience that this battery switch configuration was standard on the production Catalina 30's and was consistent through the MKIII models. If anyone has experienced a Cat 30 that doesn't have this battery switch configuration, please let me know. It is absolutely correct that this may not apply to every sailboat.
BATTERY SWITCH
