Mark
Hello Everyone!Well, I'm beyond knee-deep in my fun fun project of re-wiring my Oday 23. But, I hit a slight speed bump. I have a Perko OFF/1/2/BOTH battery switch, a 10 gang terminal block and a West Marine 12V Illuminated 6 circuit Electrical Panel. Currently, I only have one Group 27 Interstate Marine battery. (In spring I'll add a Group 24 starting battery for my 9.9 Johnson).I stopped by my "somewhat" local BoatU.S./West Marine store and the "electrical techie" said I should wire the positive from battery to the battery switch, then feed it to the positive on my electrical panel. As well, the negative feed from battery to the battery switch, then negative from battery switch to terminal block then negative to electrical panel. I did that, then installed two new cabin lights, wired them up. After hooking it all up, I had power to the electrical panel AND cabin lights. BUT - my 11 year old son put my attention on the fact that the battery switch was in the "OFF" position, yet we still had power. Is that right? Is that correct? Did I not wire something right? Any advice would be greatly appreciated. I'm not an engineer or electrician, but just doing the basics. This boat will eventually have solar panels installed for battery charging, but that's later -in spring, when I can afford more gear. Help?Mark s/v Cattivo I1972 Oday 23Frozen Tundra of Green Bay, Wisconsin
