Some Clarity
Here's what Hunter did with the 40.5 battery system.The battery cahrger has two isolated outputs, one of which feeds the house battery switch common, and the other charges the starter battery directly (throught the starter battery switch).Whichever position your house switch is on will determine which battery is being charged from the charger.Next, the alternator is connected to the starter battery. There is a large 12V DC solenoid relay above the engine, with the coil energized from the key switch. When you turn on the engine, this solenoid makes a conection between the starter battery and house, shunting them all together. This is how the alternator charges the house.Having said all of this, this solenoid will allow voltage from the house bank to the start bank, but the wire guage (#4 I believe), is too light to crank the starter motor.
