Hi, all. Is there anyone out there that has not had problems with batteries? Well, here is our latest, and we hope that someone can offer some help.Our house bank has three Group 27 AGM batteries. We live on the boat for much of the summer, so the batteries see steady, consistent use every day. We probably use a total of about 60-70 amp hours a day. We have a generator, and we re-charge daily. We have a Link 2000 battery monitor, and make certain that we consistently replace as many amp hours as we take out. And everything is just fine all summer while we consistently discharge and recharge on a daily basis.Then fall comes, and we return to weekends onboard. When we leave the boat on Sunday evening, the batteries are recharged to at least 12.65 volts. But when we return the next Friday, we find that the batteries have dropped to about 12.50. Of more concern, when we try to charge the batteries, the acceptance is very poor; we can only get a few amp hours in. Over the next two days, as we begin using the batteries, the acceptance improves, and by the time we leave on Sunday, things appear to be back to normal. But the next Friday, it is the same thing all over again; lousy acceptance, and we struggle to get the bateries to "wake up".This is the second year that we have gone through this scenario. Last year we took the batteries home for the winter, and all attempts to get them to take any charge over the winter failed. Being AGM's, however, they did hold 12.50 volts all winter, so we hoped everything would be OK in the spring. In the spring, we put the batteries into the boat, and although several discharge/recharge cycles did return some acceptance, we were not able to even come close to putting back what we were taking out, and we had to replace the batteries.We now have our second set home for the winter, with all of the same symptoms. We do NOT want to replace these batteries yet again after only one year. We have been very conscientious about adhering to charging specifications and using the battery monitor to make certain that we run in daily amp hour balance all summer.What do we do with these batteries for the winter to "rescue" them for next spring? What might we be doing wrong in our battery management?Thanks in advance for any help.Carl and Jule Dupres/v Syzygy
