Compression levers and batteries
Jim C. -- the "de"compression level does just what it sounds: It provides an escape for the cylinder compression. As you may or may not know, diesels operate at significantly higher compression than auto engines; in fact it is the compression that causes the ignition, not a spark plug (which diesels do not have). For similar sized engines, it takes more power to crank the engine because of the higher compression. If your battery is too weak to crank, by releasing the compression levers, the engine will turn much easier. It probably will not start with the levers open, however, for lack of compression (never tried it). As Steve said, what you need to do with a weak battery (first combine all batteries in parallel by setting the switch to all) is open the levers to get the motor spinning, then close the levers so the compression can start the engine.Regarding starting the engine: I agree with the conventional wisdom that your batteries may be starting to fade. However, it depends on your battery type. You may have two (small) "deep cycle" batteries, one for each bank. My boat was set up that way when I bought it. Deep cycle batteries have fewer, thicker plates which can survive multiple discharges (which kills automotive/starting batteries), but the trade off is that they cannot produce as much current flow (amperage). If you have two smallish deep discharge batteries, what is happenign is that they individually cannot produce enough amps to crank the engine, particluarly if the batteries are getting long in the tooth. When I got my boat, I bought a "marine" starting battery at Walmart for $40 bucks, which has plenty of amps to crank the engine, and combined the two deep discharge batteries into the house bank, which gives me double the storage capacity. I use the starting battery really as an emergency battery, and keep it topped off. I use my house bank for all day to day chores, including starting (combined the two deep discharge batteries produce enough amps to crank the motor).BTW -- be careful about switching your battery selector switch while the engine is running. Depending on how your system is wired, if could isolate (disconnect) the alternator from a battery while the engine is running, you can blow the alternator. If your charging sources (alternator) are hard wired to a battery (usually the house bank), you are protected, but if the charging sources are wired to the selector switch, and you isolate the alternator (e.g. by switching the battery selector to off), you can zap the alternator. Some battery switches have a "field disconnect" function to avoid this from happening. If in doubt don't switch the switch while your engine is running.
