F
Frank Bean
I need some input.....and yes I have looked at the archives........I established a 4 x 115 amp hour battery bank and it is on battery position #1 and purchased a seperate new battery for starting my 30 hp Yanmar. It is, from my best recollection a 550 cold cranking amp battery on postion #2. After installing it all and then trying to start the boat on that single battery....it just didn't want to do it.It finally cranked after clicking for a time then after turning the battery position to both. I have read several posts about additional relays for the starter or selonoids. Does that seem the logical place to go. Previously I had a two deep cycle battery's and I would turn the battery switch to both and had no issues with starting.I don't believe the issue is the battery since it is new.....but I did fail to check it. Some input would be great from other Cutter Owners. I read the posts about selonoids and relays. They were some time ago. Any change in attitudes about one over the other? Fair WindsFrankS/V Blue Shark
