Charging systems should be regulated by voltage, time, battery temperature and, perhaps, acceptance rate. They don't need energy monitors.
Can you explain how this will be easier than looking at my monitor telling me I have drawn down -50 ah out of a 100 ah bank which puts me at 50% DOD and it is now time to re charge..? I then look at it a few hours later and I'm now back up to -15ah down off a 100 ah bank. We don't need exact numbers but a close approximation. IF you discharge to 46% a few times vs. 60% it's not the end of the world..
Voltage: Voltage can be very misleading when the system is in use and batteries need to come to a resting state before a true SOC voltage reading can be measured. This takes time.
Time: You want to talk about confusing. if you have a 100 amp alternator and run it for an hour you put 100 amps back in right.... Not...! What does time tell you..?
Temperature: Seeing as most boaters would not even know the temp conversions for SOC using reting voltage or a specific gravity test (which can't bedone on AGM's or Gels), vs. batt temp this is certainly more confusing than a monitor.
Acceptance: See time above..
The battery monitor is one of the most useful tools I have on board my boat. I was amazed at how far off my well thought out energy budget was once I got one. There are a fair number of us who were very surprised at how far off we were on what we had calculated daily consumption to be and what it really was. I was amazed to watch the differences in fridge draw from day one and a warm start to day two and already cold. Time, voltage, acceptance etc. tells you none of this and unless you have a clamp on DC meter (good ones cost as much as a monitor, you have no real way to know your amp draw as many items are variable like a fridge, laptop computer etc. The monitor keeps track of each amp in and out. As I said above I don't use the % of charge screen and find amps in/out far more telling..
Benefits of a monitor.
It teaches you how a charging system works by letting you see first hand how accptance plays a role. It also allows you to see that the last 15% of charge takes for ever no matter how big your alternator is.
It can save you money, if you install it first, because you may find you DON'T really need a big money alternator as the one you currently have may not even be working all that hard.
I can monitor my alternators behavior and it's amp output. Watching this tells me how close I am to full charge or how far away from it I am.
I can monitor the output of my solar panel and then adjust & angle the panel to maximize amp output and subsequently am input to my batteries.
I can monitor my house consumption, in amps, as it's happening.
I can monitor my house consumption, in amp hours, cumulatively.
I can tell when I am nearing a 50% DOD by watching the ah consumed screen.
I can tell what phase of charge my charger is in by watching the amps in screen or the volts screen.
I can see the net effect of what is going into my batts even when running lots of loads while charging. The monitor tells me what the net input is.
The list goes on. I find it very surprising anyone would say boats "don't need energy monitors".
My buddy Tom was going through batteries every three seasons at big $$$$. He had been monitoring battery SOC via volts based on what he had figured on paper and decided his house loads were. At my suggestion he installed a battery monitor. Needless to say he is on year five with his current bank. That right there is enough reason to buy a monitor. If he gets six years out of his bank the monitor helped him understand and double the life of his batteries. This guy is an average Joe sailor and it helped him dramatically...
