hello all,
Hoping to get a bit of input on readouts I am getting on my Xantrex LinkLite battery monitor. To start I had to replace the in-line fuse holders (2) on the linklite due to heavy corrosion so had to splice in two new wires and a connector to battery. Used same size wires and fuses. I have a house bank of 2 lifeline 4d agm batteries that may be nearing the end as the p/o said they were 5/6 years old 2 years ago. So I am watching consumption and just can’t figure out how I am eating 200ah quicker than I did previously..... nothing has changed in the way we function. I left my slip on Sunday with batteries fully charge (week plugged in). No wind so we motored 7 hours. This is with my balmar 150 amp alt and external regulator. I adjusted the regulator as per mainsail to match charging of the lifelines (volts and time for bulk and absorb) and according to code read-outs all is functioning as Should be. However during trip I watched as my amp hours used continues to climb..... volts into battery according to monitor were correct matching regulator read-out and double checked at battery with meter. During trip we used autopilot chart plotter, wind, speed, stereo and freezer refrigerator.
Could the batteries just be at the end and slowly not taking a charge. Or could the monitor be acting up?
Just as an add..... my 2 weeks to block island right after I installed alternator but before the wire changes to the monitor all was typical.
Thanks!
Greg
Thanks!
Greg
