Brian
I made it home for ID with my boat. The trip was long(42 hrs). I have one bad battery that the orginal owner is replacing this week. It has a dual battery system with solar, o.b. motor charger, and 120 volt charger. I have it back out of the water to replace the battery and maybe put a dc amp meter on the boat so that I'll not run my batteries down without cranking the motor. I have radio, cd, coffee maker, lights, depth, knot, and just the basic mast light and running lights. We are planning a long weekend this weekend on the water. It also has a battery switch with 3 positions( 1, both or 2). I'm will be getting into this hard this week to try to figure out just what I have. Due to the owner's husband passing on, I'm still a little unclear on how this set up works. Has anyone installed a amp meter on this type of set-up and would you install a meter on one or both batteries. Thanks
