Battery location 235
4
Beneteau 235 Lake Sinclair
Sold my T-10 and took a 90 Beneteau 235 in trade. Very nice boat. I can't find where the battery location is on the 235. Can anyone help. Only saw the boat for a short time but in great shape. Nice sails also. Anything to watch out for?
Thanks
Beneteau 323 Annapolis MD
.... I can't find where the battery location is on the 235. Can anyone help.
There is a really good site for the B235. 'Im sure someone else will chime in here, but IIRC, isn't it in the cubby behind the head? I think i moved it to the lazz so i could slide a milk crate into that cubbby. Or is my memory gone, too???
Nov 8, 2010
11,386
The 235 is easily one of the best 22-25 footers every made.
the site is http://beneteau235.com/
LOTS of great info, to read the forums you have to join.
The standard location of the battery is aft of the head under the sliding chart table. A common mod is to move it under the port settee, this also helps P/S boat balance.
Thing to look for? The boats are generally very well made with over-speced hardware. the hull is solid and the decks almost never get wet as beneteau normally only drills in solid areas.
Transom/hull joint. A weak spot of the design. Look over the outer flange.
Mast. The Z190 spar is light for the boat and the early ones often broke at the spreaders. A 90 should have the upgraded spreader kit.
Keel is iron, check for condition, along with bolts (they are NOT nuts as typical)
The headliner, if still up, WILL fall. Just a matter of time. Fixing is a labor intensive job. Trust me.
