Our little boat has a bit too much weight aft... outboard, gastank, battery, skipper (ahem), and as a weight distribution fix I'm thinking about moving the battery forward, into an unused spot in the interior, near the bow.
It's my understanding that deep-cycle lead-acid batteries don't outgas much under normal use and charging, and that the only times batteries are dangerous are when they are way overloaded or shorted, or if they're dangerously overcharged. Assuming the battery will be well protected against shorts, and a known-good charger is used, is there any danger or downside to having the battery in the cabin?
Thanks.
Thanks.
