Battery/grounding issue
Oday 23 Winnisquam lake
Hi all. Chris again that just purchased the 1973 23 converible. Just got the swing center board all freed up, engine up and running, new haylards, stays/rigging all set and pretty much all set to go exect one thing, the battery. Since the boat had sat for 6 years or so, the battery was taking out years ago. Got myself a new deep cell, and went to hook her up, and seeing things that confuse me a bit. It has a "Guest" battery switch, and I understand this for using two batteries. Out of the battery switch, there are two "bigger" blue cables that I am thinking would go to the positive or each battery (or just use one if using one battery like me). Where would the ground wire be?? The only "black" wire i can find is a very small gague one and it goes back to where the motor is and looks like it is used for when I am charging the battery off the motor. Is this the only ground?? if so, what would happen if the motor was not hooked up?? I asked the owner about this, and he is older and as I said, had not used this in over 6 years, so he wasn't much help. Any ideas??? Out of the Guest Battery swith, there are 3 wires that goes into something mounted next to it that I have no idea what it is!! It is red, 3 wires into the top...really don't know what to say about it. Shouldn't I have like a "big" ground cable going to something metal (mast??? something??). Any help, as always would be great, cause after this, I am done and ready to go!!! Thanks much. ~Chris (chris@NOSPAMfernstravel.com) remove the NOSPAM of course
