Battery Fuses
187
Hunter 33.5 Missouri
We have an 87' C27 with the M18 diesel and 2 batteries. Electrical is not my forte by the way. So, is it possible to determine the fuse size for each battery without knowing the wire size for the batteries and the load. It's pretty much the standard factory setup with the original main fuse panel and selector switch. I would like to add the Blue Seas MRBF fuses to the house and starting battery. I looked at Blue Seas web page and it has a calculation tool but I don't have the necessary information to use it and won't be at the boat for a few more weeks. Guessing I'll need more info!
Steve
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
You are not going to want a fuse or breaker on the starter cable, ABYC does not require it and it could result in your not being able to start your engine in an emergency. You will need to protect all other conductors from the battery though. There should not be much on a boat this size though. The main conductor supplying your main panel should have a fuse or breaker around 30 amps. keep in mind the fuse is to protect the conductor not the what is connected to it in this case as the sub circuits should have their own protection. The exact size of fuse or breaker will depend on the size of the wire and length of run which you will have to figure out on the boat. Make sure any other conductors connected to the battery or battery switches are protected as well. Things like bilge pumps and other add ons all need to be fused within 7 inches of the source of power.
Capt. Wayne Canning, AMS
www.projectboatzen.com
Feb 27, 2005
187
I do understand that the fusing is for the protection of the wire. I thought that might be the case that I would need to know the run length and cable size in order to purchase the correct size fuse. Thank you for the input. I will wait until I go back to the boat and get the information.
Steve
Feb 6, 1998
11,760
Steve
Steve,
The battery fuses are always sized to protect the wire. It does not matter the length just the max ampacity rating for the wire. The ABYC allows for going to 150% of the max ampacity rating if your wire is slightly undersized, which many early Catalina's are.. These fuses are only to protect against catastrophic faults or dead shorts, which happen.
There is no reason to not protect starter batteries on small AUX sailboat engines. The ABYC "allows" an exemption but this is in no way a suggestion to not fuse. I have literally thousands and thousands of starts on batteries with fused banks and never once had a "nuisance trip" ever. In a properly sized fuse this simply will not happen unless it should happen.
This exemption only gets more complicated when we delve into a 1/2/BOTH switch. Which battery is the "start battery" and which is the "house". Neither is a truly "dedicated" start battery. When you consider that a large proportion of people using the 1/2/BOTH switch start and do house loads off the house bank, and the house bank is required to be fused if you want to be ABYC compliant, this gets into an even more gray area. Many of us involved in the ABYC, including the ABYC's own education director, have long argued to change the wording of the "exemption" for start batteries. It is one thing to exempt massive motors that require thousands of dollars in fusing to protect them it is another to allow an exemption on small motors that can very, very, very easily and very cheaply be fuse protected.
In 2005 we purchased a brand new Catalina (not used a brand new factory boat). I surveyed it myself as did a well known "surveyor" and neither of us caught the starter wire that was a tad too short. It was nearly impossible to see and when the motor was running and the wire jacket warmed and softened the wire chafed on the engine. Under a visual inspection it did not look at all as if this wire would cause a problem. In mid July it chafed through, shorted and blew the fuse. If I had not added the second fuse before taking delivery, Catalina shipped with just one bank protected, we could have easily burned our boat to the waterline.
The simple answer for fusing a start battery is that if you "nuisance blew" a fuse during starting then the fuse and or wire was not sized properly to begin with.
Any fuse on a battery bank is far safer than burning your boat down.. I have personally tested and blown a 300A fuse on 15' of 8GA wire with a 400A lithium battery bank that can supply approx 20,000 amp of short circuit current into a dead short.. I have tested LOTS of expensive fuses in my shop. That 300A fuse tripped in a split second with a dead short, as it should. The 8GA wire never even had a chance to get warm to the touch. Even if you go to the allowable 150% of ABYC you are still well protected. To put it in perspective my tests with 8GA wire were at 250% of the ABYC max allowable 150% amperage and the wire never even got warm...
8GA wire at 100% ampacity and 105C rated wire is 80A outside of an engine space. 150% is 120A outside an engine space. I went to 300A which is 375% of the 100% rating and 250% of the 150% rating.. There is a huge difference between a dead short and starting a motor. The smallest fuse we ever advise for any bank that may be bneeded to start a motor is 250A but 300A is a much better option.
For more information on this you might want to read this:
Battery Fuse Sizing - How?
DanM
Mar 28, 2011
155
Catalina 30 Galveston Bay
Steve,
I have the M18 in my C30 and have used Maine Sails tutorial to fuse my batteries.
Here is a video I shot and posted on YouTube (not even close to Maine Sails quality so don't expect that!), but it shows the amperage during the start cycle on a M18 fwiw. http://www.youtube.com/watch?v=oJyaZcsXkwo
I've never had any nuisance failures of these fuses and I can't think of a scenario where I'd need to start the engine in an emergency and the fuse was a problem.
Take care, DanM.
Feb 27, 2005
187
That's good information. Thanks Main, I went to your thread and read your post on this. As I mentioned, 12 volt tends to leave me confused at times. Thanks to all who responded. I'll get to the boat and verify the wire size and get this figured out.
Steve
Bob Mc
Apr 7, 2012
34
Catalina 28 Worton Creek, MD
Steve,
I'm a new boat owner who no idea about electrical systems. You should check out Don Casey's "Sailboat Electrics Simplified". I'm no electrician but now I have a good idea of what's going on and how things work.
Bob
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Steve,
Bob
Before you start buying books, I suggest you check out the Musings of Maine Sail section of this forum, the informatio that Stu Jackson will typically give (he has links to some great basic tutorials) and Maine Sail's "How to" articles on his company website. (Marine How To - DIY for Boaters - Marine How To)
These are great free sources to start to understand the basics.
Fair winds,
Jesse
Jun 7, 2004
36
Catalina 320 Middle River, MD
I'm neither electrician or engineer, just a boat owner who does most of the maintenance and improvements. The MainSail site at Compass Marine is a wonderful, and valuable service to all mariners as is this forum. I also swear by Nigel Calder's "Boatowners Electrical and Mechanical Manual." Calder's is a huge compendium of information while MainSail's site is a practical guide to How to do Stuff. To me, both are indispensible. Thanks to both.
