PS, you can do it for a "smart monitor" too
If your going to spend $40 for a voltage meter, you might as well spend $100 and get a monitoring system that tracks your volts, amps, amp hours consumed, etc. And you don't need an expensive "dual battery model", I had a single battery monitor that I wired into a rocker switch so I could monitor bank 1 or bank 2 (loses track of accumulated amp hours, tho'. With an amp meter you get a much more valuable indication of what is going on: how much you are drawing from your system and how much of your battery capacity you have used.
