Battery comparments for hunter 26
Thomas Holland
Can you use comparment in deck for gas tank and a battery for the motor. Hunter 26 batteries are hard to get to.
Dennis W.
An Explosive Idea
The gas tank should be stored in a campartment that is vented overboard and not in a compartment with a spark producing piece of equipment ie: your battery. It's an explosive recipe.
Dennis W.
S/V FullSailed
Benny
Is this a trick question?
Gas fumes are explosive, heavier than air and will settle at the bottom of a sealed compartment. Include a battery in the compartment and a connector can produce the spark to set off the explosive gases.
C
Crazy Dave Condom
in other words, use common sense
When ever I see questions like this, I wonder unless you truely do not know. Gas and batteries are a bad mix and if you love your wife and children, do not even consider this.
Michael
Yes
Yes, don't put the battery in the gas compartment.
However, I think what Thomas was really asking is -- is there a better place to put the battery than where Hunter puts it. He is certainly correct that it isn't a great place for it.
I just replaced my battery on Sunday, and it is a pain.
V
Vern
Time for an energy anecdote
Yesterday as I was filling the gas tank on my H260, I thought of this very same explosive subject. I looked over to the adjacent slip to make sure they weren't grilling.
40 years ago as a dumb kid working for the railroad, I had to fill an alcohol heater in the confined end bunker of a refrigerated freight car. Standard procedure was to extinguish the flame before doing so. I had done this procedure many times but this particular time, I didn't extinguish the heater.
The heater flashed in my face, singeing my eyebrows and hair. I can't explain why I wasn't blinded or even burned.
I do know this: If I had been filling a gasoline heater, I would have blown up the whole end of the freight car, including me. At that moment, I learned how little energy there is in alcohol.
G
George
Battery Again
Hope you have lots of life insurance -- your family needs you.
Here's some alternative options: http://h260.com/electric/electric.html
