My 1999 H410 has an electrical system composed of a house bank of 2 4D batteries and 1 SRM-24 starter battery, Freedom 20 Combi inverter/charger and a 80 amp alternator.Hunter chose to wire these with a battery ISOLATOR and a solonoid (relay) which connects both battery banks when the starter circuit is activated. (There is seemingly no way to manually "parallel" the battery banks other than this solenoid.) The batteries seem to me to be continually undercharged ( 12.6 volts typical floating voltage).
I have two issues/questions -
1. I think using an isolator could be improved by changing to a battery COMBINER to avoid the voltage loss inherent in using an isolator. Has anyone made this modification to a similar sytstem (with the Freedom combi) and what experiences / issues did you encounter? ( I know the archives contain my posts on how to do this to a H29.5)
2. It seems to me that the solenoid is lacking in some possible respects - 1st it might not work in low voltage situations - exactly when you want it to work! and 2nd some people say you want to actaully isolate your house batteries (and any sensitive electronics) from the starting process as much as possible. In fact some battery combiners have a circuit which disconnects the combiner during starting for just this reason.
All thoughtful comments would be welcomed.....
