Again with all things being equal, they usually won't, and I have not seen this in multiple real world experiments. With batt voltage sensing this CAN greatly increase charging if the system has a voltage drop between the B+ and battery. Was working on a boat yesterday with a 1.2V drop between the alternator and battery bank. It had a Balmar regulator but of course it was installed incorrectly, as many are, and did not sense the batteries that were under the v-berth. The only way to fix this sytem would be with an external regulator and battery sensing or to wire an internal reg to sense the batteries not the B+.
This is a perfect example of real world issues. Like, take me, for instance!!!
I took the "shortcut" route of having the battery sense wire connected to the AO when I installed our MC-612. As you know, we also have a Link 2000. By habit, I would check the voltage at the regulator, and the amperage at the Link. Always looked fine to me.
Last week, after two grueling days of motoring, I happened to check the voltage at the Link 2000, and GUESS WHAT?!?. I was losing almost that same 1.2 V that Maine Sail described.
Just yesterday (really, honestly:naughty
I bought a length of wire to finally install the battery sense wire to the bloody batteries, just like the instruction manual tells you to do.
I spent a week checking connections and confirming the integrity of my AO wiring, grounds, the shunt - you name it.
I finally came to this same conclusion, and all because: first I'd been lazy in the installation, and second, because while I have great instrumentation, I'd only been using the AO voltage display at the regulator and the amperage at the Link, not reading the voltage at the Link 2000 while the alternator was working - until last week when I thought "Houston, we have a problem!"
The battery sense wire goes in tomorrow.
Too bad there's not a "humble pie" emoticon!!!
Thanks, Maine Sail.
