So due to an unexpected hernia surgery, my summer sailing season was suspended before it even started. So to console myself I bought a raymarine t1000 autohelm. Which in turn made me think about battery charging. Up till now the battery ran the radio chart plotter and nav lights (if needed) perfectly fine and I would recharge at home. With this new draw I decided to use the charging on my tohatsu. The wire they supplied was too short , and I did not really relish the connectors just dangling out the transom when not in use. After hours of research on the many connectors out there. I settled on these solar 2 pole connectors. And a covered “female” socket on the transom. Used 14awg dual wire to run to the battery and solar connectors at the battery (with in line fuse) now I can plug in the motor, storable solar panels (either at the companionway or at the stern, while at anchor) Tiller pilot has a dedicated circuit as well. Still need to tidy up the wires but everything works
