Battery charging on the 192
I think that a 5 watt Solar panel is the way to go, and the outboard generator is a good idea, provided that the wire and connection is suitable. I replaced the generator wire on my Johnson Sailmaster 8, last year with #10 marine duplex cable from the connection on the engine to my 100 amp hour battery under the cockpit. Belonging to a club and having access to a dock with shore power, I was always able to top my battery off by running an extension cord to my portable deep cell battery charger in my boat. I don't do a lot of night sailing anymore, so I'm not using running lights that often. I also never turn on cabin lights, as I have a gimbaled Kerosene light in the cabin. At night, in a smooth well protected anchorage, I burn two candles. I stopped using an anchor light years ago. My 222 can get into some very shallow water and I see no need for an anchor light except on those rare occasions, anchoring in unfamiliar places. It really depends on how much load you're drawing off your battery. Most of the time, I'm running an Autohelm autopilot and my radio, and that's it. Your biggest draw is going to be your running lights. It probably wouldn't be a bad idea to convert them over to LEDs if you do a lot of night sailing. I don't advocate that you use candles, or a kerosene light. Anything with fire connected to it is always going to be dangerous. However, they do sell small battery operated LED lights that you could use in the cabin for reading at night, and also small self contained solar lanterns are available which are made of Stainless Steel. This is what I'm planning on using in the near future. Just figure your total consumption of amp hours, by getting a total of bulb wattages and converting it to amps using Ohm's Law. The total of amps and hours of use, will give you the amp hour usage. Whatever that amp hour consumption is, is what you need to restore back into your battery.
