Battery Charging from Shore Power
1
2 Vision 32 Idaho
Just acquired a Vision 32 (1989) and was faced with replacing all batteries. Now I am questioning if I should be leaving the battery charger on at all times when at the dock. Will the factory charger keep from overcharging the $400 in new batteries I just purchased? Is it safe/ best practice to keep these batteries charged with shore power battery charger on during the week or longer that I am away?
Thanks.
Dec 2, 1999
15,184
I suggest that you dump that charger. Xantrex has the XC model which I purchased a couple of years ago. It will all you to have multiple battery types on a single charger and it also takes good care of them.
Considering your current charger, I would turn it off until you find a suitable replacement. If you need a charge on the batteries, you could leave it on for a few hours a day when you are present.
What type of a battery bank do you have?
Dec 3, 2003
544
None None Rochester, NY
I agree. The old battery charger technology kept a continuous charge on the batteries, eventually causing them to over-heat and evaporate the fluid. If you have a refrigerator running on-board at dock-side, I would invest in a new automatic charger such as the Xantrex. I bought mine reconditioned on E-Bay and saved a bundle. It works great!
Charged batteries will hold their charge for a long time with no load. Make sure your battery switch is off when leaving the boat. The only thing that should bypass the battery switch is your bilge pump.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Start by determining the brand and model of your current charger. If you just acquired a 20 year old boat it is possible that charger could have been replaced by a PO. Look up the specs of that charger and determine if it has a maintainer cycle. If it doesn't then replace. If you have a refrigerator I always like the convenience of keeping a few cold beverages and keeping it cold to be able to get underway at a moments notice without having to preecool it at the dock or from the batts. Also should your bilge pump decide to run 24/7 it will not kill the batteries and perhaps keep the boat afloat. It also nice to know that batteries are fully charged and ready to go.
7,733
Alden 50 Sarasota, Florida
I agree with Benny. I think the first two comments presumed you have an old charger not capable of properly maintaining the batteries. It will cost you nothing to verify you need a new charger before you just to the conclusion you need one.
