Don Alexander
I keep my boat on a mooring in the middle of a river so have no access to shore power. Also I have a Heart Interface Freedom 10 (1 kW) static inverter which includes a 50 amp charger.My plan was to use a 700 watt AC petrol generator plugged into the boat's shore power socket to gain the benefits of the high rate charging plus the three stage control of the charge from the Freedom unit. Having bought the generator I am dismayed that the Freedom initially connects the generator but after 4 seconds simply switches the charging circuits off. It waits for about 30 seconds and repeats the cycle. It does this endlessly. I used the power sharing feature to reduce the input current to 2 amps but to no avail so I e-mailed Heart Interface but was not favoured with a response. As an electronics engineer I would be able to make alterations or adjustments to either device.Has anyone else suffered and/or solved the problem please and if so how?Regards,Don Alexander donalex@compuserve.com
