Battery Chargers
Jeff
I currently day sail my Mac 26x and have a single deep cycle battery. I am putting the boat at a slip and I'm concerned about what type of battery charger to use. I don't want to have to remove the battery from the boat to charge it, but that is what the instructions say for most non-marine battery chargers. Do I need a marine battery charger to charge the battery in the boat? What type do you recommend? Also at some time in the future I may want to add a second battery (separate house and starting). Is there any disadvantage to buying a charger now that is designed for two batteries and using it on just one, leaving the other charging circuit disconnected?
Timm Miller
Guest Products
Look at the Guest Line.......they will have whatever you need whatever you decide to do
Bobby T.
battery charger
i use this one (see below link). you can either use the included clips or "hard wire" the unit directly to the battery. when you add a second (house) battery, use an isolator and it will re-fresh both bateries and keep them at the same charge level too. the instructions are self explanatory. Plus it's small and light weight.
