E
Ed
I have a 2002 326 and I am checking out all the systems to be sure they are working correctly (have found some problems) My recent delema is if the battery charger is working correctly - and gettin a straight answer as to how it is connected through the battery selector switch.First question/issue- the owners manual for this type of charger states that the LEDs indicate if it is charging and in what mode - fast, trickle etc. No lights are comming on, but I can hear the batteries gasing if I hook up shore power and turn on the battery charge switch, I am conserned it might be only outputting max charge and am a little woried so I have only been charging the bateries with the engine.Secound issue - if the battery selector switch is in the off position will the battery charger charge both batteries? I have been told yes, this is the proper way to charge as if there is any shorts etc, the batteries wont run down at the dock but will be able to be charged, conversly I have been told no put the selector to both. I think the off position is corect - but would appreciate some input. Thanks Ed
