Replacing my outdated battery charger. One starter bank, an one house bank. What amp size are you currently using??
Purchased the following unit in 2003. Supports a 500 amp house and separate 80amp starter bank:
Electrical Specifications - Inverter
Output power (continuous) 2500 W
Surge power (AC amps) 62.5 A
Output frequency regulation 60 Hz, quartz regulated
Inverter voltage regulation 120 V +/-5% true RMS
Output wave form Modified sine wave
Efficiency (full load) 87%
Peak efficiency 93%
No load current draw (idle mode) 0.12 A
AC transfer switch 30 A
Electrical Specifications - Charger
Charge rate 130 A DC
AC input voltage range 90 − 130 VAC
Battery voltage (nominal) 12 VDC
Battery voltage range 10.0 − 15.5 VDC
Low battery cut-out 10.0 VDC
AC input (max. charge mode) 26 A AC
Bulk charge voltage 14.4 VDC
Float charge voltage 13.5 VDC
Equalize charge voltage 16.3 VDC
Battery charge outputs 3
Charge control 3-stage
Battery type settings Wet/Gel 1/Gel 2/AGM
Equalization Yes
Temperature sensitive charging Yes
General Specifications
Optimal operating temp. range 32°F − 104°F (0°C − 40°C)
*derated below 0°C and above 40°C
Optional remotes Freedom Basic Remote or Link instrumentation
Dimensions (H x W x L) 7.9 x 11.5 x 13.2” (201 x 292 x 335 mm)
