I recently replaced my two 4D AGM batteries with 4 wet cell 6 Volt batteries in Series/Parallel to make two separate 12Volt battery bank systems. They are combined thru a standard 1-2-both switch with a separate switch to control the engine alternator/starter connection. I have a smart charger that keeps both of these battery banks charged when on shore power that has the ability for a 3rd battery bank. The engine alternator charges the battery banks when the engine is operating. I would like to add a separate battery for the engine starter using an automatic charging relay. I would then have two house battery banks which I would probably combine into one house bank and one separate engine starter battery. I have studied the wiring diagram that is provided by Blue Sea and I question whether it is possible to use the “add a battery” package deal. I’m concerned that the large difference in size (amp hours) between the two battery banks will cause problems with charging via the alternator thru the ACR. My question therefore is : Is using an ACR to provide for charging the two battery banks the way to go in this situation or do I need to explore other options?
