battery/A B Refrigerator
Morris Thorpe
I have a supercold A B that runs on 12 volts and we use the boat not only for sailing but also as a cottage for the week end and sometimes during the week so we have stuff in the refrigerator all the time Is there some way we can run 110 volts to 12 volts with out going through the charger As having to charge the battery all the time give them about a 3 year of life. i do have one of the smart charger
Dec 2, 1999
15,184
Gel Cells or AGM batteries.
Morris: We have left our battery charger running for 15 years. Our original batteries lasted about 3 years. We orginally haad a Pro-Mariner 20 charger (not the type for Gels) We had these batteries on the boat for over 10 years without even thinking about them. When these batteries finally gave up the ghost we got a Stat Power 40 Plus. We also changed over to AGM's. I hope to get another 10 years from these batteries.
Rick D
Jun 14, 2008
7,187
Morris: 3 years is it anyway...
..in my 25 years of experience. Even if you don't leave the charger on. Steve is right, either toss a cheap battery at three years or pay several times as much and get ten. I put in golf cart. Long cycle life and cheap too. Good luck. Rick D.
G
Guest
110v to 12v DC conversion
Is easy depending on the amperage you need. I assume you are talking about 110 'shore' power going to the boat and leaving the charger on to charge the batteries to supply the refer with 12V power (whew !). If that's the case, what you need is a 110/12V power supply unit that converts the 110 to 12V directly and leave the batteries out of the loop. These are available in many sizes/prices. What you need to determine is the startup amp draw on the refer unit and get a unit that can handle this startup load intermittently (cause it only lasts for an instant). That unit will handle the running load easily. Hope this helps. Jerry
