It is all about power usage and production
Hi Bob. I have a 37 hunter Legend with refer and inverter (and lots of other small stuff) and I use 2-100ish AH deepcycle batteries for the house bank and 1-100ish AH deepcycle for the start battery. Yes I know about the "you shouldn't use deepcycles for starting but it is only a 35 HP engine and the starter only draws about 75 amps when the engine is cold. The inverter draws more than that!! I use it mostly for weekend reft ups where there is no shore power and have never even had to tie in the starting battery to get the engine started on Sunday morning. (I usually forget to switch and just start the motor)Not knowing what major electrical items you have and how (frequency) you use them makes it real hard to advise you. I can tell you that you most likely have a 55 Amp alternator so you will be getting around 45 AH of charge for each hour the engine runs.Having a big battery bank is all cool and such but if you can't replenish it in some fashion (shore power for 5 days, or an hour a day running the engine, wind, solar....) that is reasonable, it does not matter how big the bank is you will eventually run out of power. It is all about knowing how you intend to use the boat.
