Batteries
Sep 10, 2012
23
Hunter 36 Jamestown, RI
What's the most efficient way to charge the batteries? At the mooring ball using the generator or motoring with a load on the engine?
7,507
Alden 50 Sarasota, Florida
Which has a larger charge capacity - the battery charger or the alternator?
What is the battery bank capacity?
What is the alternator actual output at 2000rpm?
All of the above factor into the answer. Absent more info, a good guess would be the charger.
May 24, 2004
7,185
CC 30 South Florida
In general terms with a stock EOM system I would say it will be more efficient to run the generator and inboard charger. Hours on the generator are usually less costly than hours on the auxiliary engine. Depending on how deeply discharged the batteries are the recharging time will not vary much. Understand that either method will take hours to bring batteries to 100% state of charge as the rate of charge acceptance by the batteries diminishes as the batteries acquire charge. On the average 4-6 hours will do the job.
Jun 1, 2009
1,847
Hunter 49 toronto
I have some home work to do. Thank you for the replies.
Running your engine just to charge batteries is not great for the engine.
Without load you can glaze the cylinders.
Typically, the average charger / inverter puts out about 100 Amps at full charge.
A large Balmar will be similar, but it's much more efficient to run the genset.
930
Hunter 410 full time cruiser
Most efficient way would be with solar. But if I had a generator I would use that before I used my main engine
Jun 1, 2009
1,847
Hunter 49 toronto
Cylinder glazing
http://forums.catalina.sailboatowners.com/showthread.php?p=1061319&highlight=glazing
Glazing seems to be a non-issue. Besides, idle speed will get almost nothing out of an alternator out of gear. Most reports are at least 1500 rpm, which gets amperage out of the alternator, which means there IS a load on the engine. If there was no load, the engine temperature wouldn't go up, would it?
I found that at 1500 rpm, I wasn't getting adequate charge. Needed to run at about 2000 to optimize the alternator.
I was warned by 2 mechanics that running with no load for 2 hours per day ( 1 hour morning, 1 hour night) was really not good for the engine, and promoted glazing over time.
Having said that, I would definitely charge with a genset versus engine. Lot more efficient, quieter, etc.
Jan 12, 2011
930
I tend to believe what my manual says over various yard monkey myths and it says you can run you engine at idle, just to run it up to 3000 rpm for a while every few hours.
eianm
Jul 7, 2010
523
Hunter 42 Sydney
another option i have considered is an auto start module for the gen set- there seems to be multiple vendors of this type of product. It is installed to monitor your battery bank voltage and when it hits a low voltage level you have set, it automatically starts the gen set and then runs it until batteries reach the fully charged level - that you have also set- might be worth considering , if living on a mooring.
JamesG161
Feb 14, 2014
7,829
Hunter 430 Waveland, MS
I am not sure how to "glaze" a diesel or gas engine. If they meant carbon deposits, then there are additives and engine exercises ( vitamins and gym for humans) to help prevent/remove carbon from critical engines parts.
Efficient is a term for engine engineering, but the "ideal" way is to use you genset and a inverter/charger which has charging curves for house batteries for optimum charge. This gives longevity to your expensive deep charge battery(s).
BTW your engine alternator has a crude voltage regulator to charge "high amp output" starting batteries. I would only an alternator to charge a house battery in a pinch. Plus there is a "working charge" between 12.5 and 11 volts which is about 85% of total house battery rating. If you have the Amps/voltage in your charger, then you can recharge (85%) in usually around an hour. Then the next 15% takes hours, which done by a modern charger. Extends battery life by a slow "trickle" charge to "top them off".
Efficient to me is... charge when i need high power demand times. My genset is 9kw and battery charges as a "side issue". Most genets "idle" until Amp load increases. So combine power use on a schedule for most genset fuel efficiency.
Happy cruising and long battery life....
Jim...
Feb 6, 1998
11,713
Guys lightly loading a genset is no different than constantly light loading the engine... Also keep in mind that many inverter / chargers can perform quite poorly on a genset putting out fractions of what they are truly capable of. If you have a well matched genset & inverter charger then running the genset is a good option if you can also use other AC devices while charging...
With either engine or genset charging for more than about 20-30 minutes beyond hitting absorption voltage is very inefficient and is simply a waste of energy...
7,507
If you ever feel the need to be further convinced "glazing" is a myth, drive by any roadside truck stop at night.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Great point Don! When we travel with our trailer we sometimes stop at a rest site. They should call those "daytime rest sites". At night those truckers run their tractors all night to run either the heater or A/C! Glaze my butt! You are right on! Chief
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
Great Point Don.
I'm not an expert, but as w the newer cars, better fuel, cleaner more efficient engines, many of the old engine myths are going away. I'll be look for the glazing on my donuts.
Bob.
