Batteries Hissing
G
gr8_2_av8
I ran the engine for about an hour last night, then after shut down I notice that one of the batteries was making a hissing sound. The are just 12 volt wet cells. Is this normal?
Jun 4, 2004
125
Hunter 333 Elk Rapids, MI
not normal!
Sounds like you are boiling a battery. Carefully check the water level and then check the charge rate coming from your alternator.
Jun 4, 2004
125
not normal!
Jun 3, 2004
95
Boiling Battery
Have not had this problem on a boat but a number of years ago I experienced it with a car. The hissing caught my attention and lifting the hood disclosed a battery that was bulging from the pressure. Problem was a voltage regulator. If I ever discover a similar problem on my boat I will quickly disconnect the battery as pressure being released is not normal and in my opinion very dangerous.
