Battens
Other Catalina 30 Tucson, AZ
Eudorajab: I am not a batten expert but I'll provide what little I know. First, some listers may be interested in the purpose of battens in the first place. The luff of the main is supported by the mast, the boom supports the foot but the leech would have no support were it not for battens. The main would be as limp as a dish rag without battens so that is why we have them. Full battens give better control of the leech than partial battens and that is why they are becoming more popular. Obviously, they are more expensive than partial battens and they require special engineeringto build. They come in various stiffness and flexability and your choice depend on the type of weather you sail in. Additionally, your choice for the top batten pocket is very important. So, if you are sailing in lite air and want more power and curve you would use a flexable batten. If you are sailing in heavy air and want less curve and less power you would choice a stiffer batten. I checked with my sail maker in Torrance, Ca to determine the advantages and disadvantages of full battens over partial batten. He told me full battens are quieter and easier to flake. They give a better shape and hold it better in lite air. The disadvantages are that if they are not properly designed they will jamb at the luff and the sail tend to chafe against the shrouds when running. Lastly, there is the expense factor but he claims they are more durable and therefore last longer. Eudorajab, I'm afraid I have not been much help. You will have to press your sail maker for more information as he is the guy who built the sail. You paid hard earned money for his product and you deserve some answers. The bottom line is that you have to get the proper set for your sail or you'll never get the trim right.
Tim McCarty
Hey Don!
My wife and I just purchased a new Catalina 310 with in-mast furling. Knowing that I was going to be losing sail area with the main, I opted for the 150 genoa to make up for lost sail area. Question: Am I gaining anything? What am I losing? The main will have a loose foot. My brother-in-law sails a C&C 99 (which we sail on when we want to go really fast!) which also has a loose foot, and considerably more sail area (understandable on a cruiser/racer). Really, just interested in your thoughts on what you really lose with a furled mainsail (no battens, limited trim controls etc...)...
Battens:
Tim: Life is a trade off and you lose a bit with the mast or boom furler system but you knew that going into the purchase of your beautiful boat. You indicated that you have limited sail trim controls? You have the essentials such as the traveler, outhaul, halyard (I prefer a Cunningham), and hopefully a soft boom vang - a rigid vang would be better. The next step is to know how to apply these sail trim controls on each point of sail and wind condition. You have to be a little more precise to get 100% out of the sail. Now for the good news!! The engine on a mast head rig is the jib - on a fractional rig its the main. Same deal on the 150 as on the main. To get the most out of the sail you have to master the fairlead, halyard and sheets adjustments for each point of sail and wind condition. You have to be able to read your telltales and adjust accordingly. So, you ask, just what are all the adjustments for the main and jib for all points of sail and wind conditions? Surprisingly, there are not that many but there are too many to outline in this short space. Take a look at my Sail Trim Chart, which is available through the ships store. It outlines every adjustment you'll need to make. After a few times practicing with the chart, your brother in law will asking you for tips!! My Chart tells you WHAT to do and my book telss you WHY you are making a sail trim adjustment.
