Batten
R. Thompson
I was hoping that someone would have the measurements (including thickness) for the Hunter 240 Battens. I have read all the posts about securing them in place and will try out a couple when I can replace the ones recently lost. Thanks
C
Crazy Dave Condon
Buy the 5/16 inch wide batten mateial
You can order batten material in a 12 foot length and cut it to size. When you do, round off the edges. Check with the HOW chandlrey if they can get you a 12 foot section. If not, let me know and I will direct you in the right direction. Crazy Dave Codnon
C
Charlie Kilmer
Any luck with batten specs.?
R. Thompson, Did you ever find out what the specifications were for the battens on your H240? I lost my top 2 during a race recently - the topping line snagged the velcro straps and they popped out. So, I too am looking for the length measurments. Any help would be appreciated. Charlie "Good Medicine"
Sam Morgan
Dave, what size for 260
Dave - what size goes with the H-260? Sam
Tom
Batten info for 260...
You'll need 5/8, non-tapered stock. Can order it from: Doyle Sails, Marblehead, MA (781) 639-8086 scott_loomis@doylesails.com Or from West Marine, part number is 414136. Lengths used on 260 (from previous HOW post by Bob Metz on 08/22): (2) 30 3/8" (1) 39 5/8" (1) 68" I had this problem once before, and I ordered stock a little long and cut it to size with a hack saw. Fair winds, Tom
