G
Geoff
I am a rookie re the battery and charging system and have tried to educate myself by reviewing this forum and various battery sites. I still have questions. I can't believe how complex it is to determine your system configuration ie check for factory wiring errors (I think I may this) and then determine if your system components are all working.Boat is a Hunter 340 -2001 with 2 deep cycle Grp 24 automobile flooding batteries. I sail L Ontario and to date I am at shore power every night. Batteries are largely required for fridge, auto pilot, new chart plotter(C-80) and radar (infrequent). This summer may be on the hook at various crusing stops. I purchased from previous owner - batteries of unknown age/condition. I have abused them in the past 2 years by leaving them on the boat overwinter and only charging them up in the spring. Worse I thought they were no maintenance and did not add water regularly. When I did this year the 2 batteries took on a jug of distilled water. Oops. Hydrometer reading are now in the red zone for both batteries. However each individually will start my 3 cyl diesel no problem. I have never had a battery issue but likely have never really drawn on them.I have a Pro Mariner 1230 charger that shows LED lights in trickle mode and batteries show 13.26V currently. Looking at the charger wiring I have a bridge wire going from red terminal 1 to red termnial 2 at the charger - I don't believe this is correct based on forum reads. Correct?Batteries have a dedicated red cable to each positive terminal but are bridged at the ground black terminals. Correct?I plan to carefully check the wiring in the battery switch and the charger, map it out and confirm it is correct. Not sure what it should be though. I also expect to be challenged in mapping the wiring at the main panel as it appears daunitng with all of the wires! Also not sure of the need/value of isolator ie the new switch and isolator package that West Marine promotes to isolate charging battery. Not sure if mine are even isolated now? I think not. Someone suggested I just leave the switch on 'both' and have done so. Also think this is incorrect ie can risk draining both batteries. To test the system I plan to discharge each battery separately under load (any suggestions on how to do this? ie turn on fridge etc and wait for battery to run out?) Plan to recharge it and learn if the batteries, while still working, have minimal reserve as hydrometer would suggest. How do I know what is 'unacceptable or accpetable'? Not sure if I can separately charge each battery? Not sure how to do a equalising charge as suggested every once in a while.Finally I am considering AGM type Optima deep cycle blue tops due to capacity and no maintence required. I notice on the Pro Mariner charger it has only 2 switches for flooded and gel batteries only so emailed mfr. Response was to simply leave it on flooded mode. However thier newer chargers have 3 battery options ie 1 for AGM. What am I mising by using an older charger in the flooded mode. I sent the Optima charging profile to the mfr but they did not reference this in their response. I was not satisfied with the lack of technial content in thier responsee that flooded mode was OK.Finally Optina says to charge at 10 Amps maximum yet the full feature chargers are all 20 amps or more. Will this be a problem? I am thinking of a Xantrex TruPower 20 if I require a new charger. Thoughts? Thanks all!Help! Te real experts are on this Forum.
