Mike Whalen
Don and others with lines aft. I've emailed the folks at Rudy's about the plate needed to go under the mast base plate (or whatever its called) to allow me to do the same. Is there a proper plate? Is it one size fits all? Will I have to drill holes in the "new" plate? I assume you have to take the hinged plate off put the "new" one on and then re-atach the hinged one. Also some type of silicon? I don't have time now to try and manufacture one where did you get yours?Thanks,Mike
