Interlux worked well
We used Interlux 2000. It's expensive, but Defender offered it for nearly half price during their spring sale last year. Hopefully, they'll do it again. I believe the sale is usually at the end of March. Anyway, we have had good luck with the barrier coat. We live in R.I. too, so we waited until early May to apply it. (Don't do it on a hot day!) A gallon produced one coat on our Oday 26. We used two coats. Applying the stuff was a bit of a challenge. You have to mix it as you go, otherwise it will dry up in your paint tray. Make sure you work fast enough to apply the next coat while the previous one is still tacky. This is definitely a two-person job. As mentioned in the other posts, apply your antifouling paint next, before the barrier coat dries. This saves you from sanding and cleaning. After applying two coats of barrier and two coats of antifouling, we were ready for bed. We had a busy sailing season last year and the bottom still looks great. Good thing you only have to barrier coat once. It's tedious.
