Barrier Coating under Cradle Pads
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Hi,all. I'm biting the bullet and taking my '88 H285 hull down to bare fiberglas and doing the Interlux 2000 barrier coat job (good time of year and I have an extra week of vacation I need to burn!). I plan on stripping the little paint I have on her while she's on the cradle, then moving her onto some jackstands so I can do under the cradle arms, but the big question is...if I put 4-5 coats of barrier coat under the cradle arms over the span of 2 days, how long does she need to dry before I can lower her onto the cradle in order to do under the jackstand pads? I hope a couple of days' drying time is enough! Also, is there anything I should put petween the new barrier coat and the cradle arms? Plastic sheets? Wax Paper? Any ideas????
Steve
Read the label
I did that job on my H356 last winter. Why I an not sure because I traded her in this summer. The label on the Interlux can tells the drying times. The warmer the faster. I recommend getting a really good orbital sander for helping with the removal. A high pressure power washer did take alot of our old paint off. Also, I tried the chemical peel and that did take off quite a bit of the old stuff. You will go through alot of rags and paint thinner to wipe it all down. If you spray on the barrier coat you will get a smoother finish. I actually did all of the prep and then had Larsen Marine do the barrier coat and the VC-17 applications. Call me if you have any questions. My bottom job just seems like a bad dream now. If I had a week off, I would find some friends to go sailing with and pay someone to do the bottom job. Steve A 847-417-1394
