Since Winter Dream'n #118 was new she has had yearly coats of VC 17 - I sail in fresh water - Lake Erie. I am doing some fiberglass repair for cracks around the prop strut probably caused by a failing cutlass bearing that I just replaced two weeks ago. My question is after the repair - about 1 foot square area - should I use a barrier coat such as VC tar before the VC 17. How many coats should I use and is there any special prep to do before or during the process other thancleaning with a VC solvent?
