Quality and features
Buy the best quality you can afford as a good one should last a lifetime. A good heavy enclosure, regardless of material, will protect the instrument from shock damage. Of course, you must get one with a tell-tale. That's the adjustable marker moved by a knurled knob on the face. We're only interested in relative movement of the aneroid needle from where it was at some time previously. The fact that it's at 890mb, in the "rain" portion of the dial is irrelavent. You're probably already aware that there's a hurricane out there by other observations, ie...your anchor just flew by your head! The trend is what you're looking at. Some come with temp., rel. humidity in same instrument. Some are luminescent. Weems and Plath offer some pretty nice ones and will stand behind them. I wish someone made a recording barometer (barograph) in a small size. It's easier to track the trend. I also wish I'd saved the chart off the one on the SS President Madison when we were in that typhoon off Keelung. I know the drum was turning, but that ink line sur looked vertical when the bottom dropped out. Guy
