I removed and cleaned all my winches this past winter except for the Barlow 16 on the mast used to raise my main sail. How does one remove the Barlow? The archives here, on other forums, and the Hutton-Arco site say there is either a retaining clip, a hex bolt, or a push button in the center of the socket. I have none of that. The center inside looks like a slot for a regular screwdriver. I tried a large screwdriver but I can't seem to turn it either way. Maybe an impact wrench? I try every weekend when I go down to the boat, but I am afraid I will end up stripping the slot. Is this a slot for a screwdriver? Anyone on here ever disassemble this type? Being mounted sideways there is no good way to spray penatrating oil inside it. The winch is bolted to a plate riveted to the mast. I may be able to remove the four nuts and remove the winch to get to the inside to spray penatrating oil. But once removed, if I still can't dissamble it for cleaning, grease, and new mounting bolts, then I will have to buy a new winch which means redrilling the plate cause I'm sure new winches will have a different bolting pattern.
The boat is a 1982 34' shoal draft O'day.
Many thanks to all
mitch
Many thanks to all
mitch
