Barient winch retaining clips?
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
Yep. I had to have parts shipped from them when I cleaned/refurbished my 3 Barient winches. Still cheaper than new winches.
Sep 27, 2008
159
Hunter 33 salem
thanks Its actually called an O-S%^&% clip.
That's what I said when it went flinging over the side anyway
Feb 8, 2014
1,300
Columbia 36 Muskegon
Oops. I've always serviced mine on the hard (I'm in Michigan, we have six months a year to do these things) so I've never lost a winch part. But I did read somewhere to take a deep cardboard box and cut a hole in it the size of the winch and place it over the top. Disassemble inside the box. Then anything that pops off probably won't get away.
May 27, 2004
2,057
Guys, Cow gone, barn door closed later!
They're called "cir-clips" or "retaining rings" and if you can measure one from another winch, you can source them in the USA. You can measure the shaft slot they mount in with calipers to get inside diameter and buy different outside diameter sizes to cover the range. They don't cost much.
Good luck.
Likes: Dalliance
Jul 7, 2004
8,497
We would need a picture from the OP because I don't recall any standard circlips in either size Barient I just serviced.
