Help! I just changed the choker line on my Nonsuch wishbone and the Barient 17 ST winch stripper is bunching up the line cover and causing it to bunch up and jam when i am cranking. Interesting enough it does not do this with the other older lines (topping lift, reefing lines and Cunningham) that I use the same winch for. I even changed the line out and got a super non stretch line and the problem continues. All help appreciated.
Reef early,
Reef early,
