Barber hauler/twings
letlmt
Oct 21, 2018
151
Catalina Capri 22 Lake George
How many of you use either barber haulers or twings (or both)
RussC
Sep 11, 2015
1,680
Merit 22- Oregon lakes
Not a C22, but I sometimes use a barber hauler on Aye pod (Vagabond 17). it does give you a bigger range of trim adjustment on the jib when you're searching for speed. (note between port lights on jib sheet) .
I have never used either, but would if circumstances dictate. The twing seems, maybe, a bit more flexible.
-Will (Dragonfly)
Jul 28, 2016
95
476
So, to be clear, my perspective is based on my use of the boat, which is almost exclusively for racing on the Great Lakes. On both of my boats we did end for end jibes and used a single set of sheets on the chute. The lazy sheet acts as the guy. We ran twings on both sheets, to control the lead angle of the guy, and occasionally on the sheet to choke down the sail.
We use a barberhauler to move the sheeting point of the headsail for improved sail trim when not close hauled. This is usually in heavy air reaching conditions, when we don't want to fly the kite, or on those rare occasions where we are racing in a JAM fleet.
