Does anyone happen to know the Yanmar and/or Torresen model or part number for the "banjo" washers used on the fuel system bleed screws of the Yanmar 2GM20F engine?
In the parts catalog, these part numbers are listed for the 2GM20F:Gasket 6, nylon PN 23418-060000Gasket 8, PN 23414-080012They are used on the bleed screws on the top of the filter housing.Hope it helps!
they will send them out the same day on a credit card order. They are a 'regional' distributor for Yanmar / Mack Boring - the eastern US 'master' Yanmar distributor.(410) 263-8370http://www.bayshoremarineengines.com/
... with the bleed screw washers. They are different animals and sizes.Banjo washers are used on the high pressure fuel line (metal tubing) fittings where the fitting looks like a banjo. Mine on a 3HM35F/3GM30F are about the diameter of a dime. I got a pack of them at Mack Boring.
PN 23414-080000 for the lifting pump, 2 minimumPN 23414-120000 for the in and out of the filter and into the injector pump.6 minimum to do these joints.I bought about 12 of each just to have extra.Joe
