Thru-Deck Holes
One area where the manufacturers SHOULD epoxy seal is where there are thru-deck holes: Genoa tracks, furling lines, hatches, etc. When these holes are open and the deck material is clear and clean it would take comparitavly little time in a production environment to properly epoxy-seal these holes. The cost from water infiltration and damage in these areas is probably a thousand time what it would cost to build the boat properly. One poster said it cost something like $10 or $15K (exact amt??) for him to repair the damage on one side of his boat from a leaky genoa track and furling line holes.The January 2003 issue of Seaworthy, "Why Fiberglass Boats Sometimes Fail – a Primer on Boat Construction", http://www.boatus.com/seaworthy/swhigh.asp, says that "whenever a hole is drilled through a core below the waerline, it should be tightly sealed with an epoxy paste and then caulked to prevent water penetration". BoatUS says this because when wood rots the member looses strength. Wonder which builders do/don't do this? Also, even above the waterline, if water sets or is impeeded in flow it can easily find it's way into the deck through the smallest of cracks. My boat has recessed genoa tracks, probably for safety to prevent stubbed toes, where the water can sit just waiting for a chance to leak into the core. Resealing all the thru-bolts on just one side is about a two-day job for two people.The genoa track has LOTS of holes, to be sure, but there are large loads on the track which, if sealant was the only thing keeping it water tight, tends to fail easily. To expect the new owner to come behind the manufacturer and dismantle everything, clean out all the sticky sealant and do the job right is expecting a lot. Either they should have solid impervious fiberglass or build it right.In many areas Hunter apparently has put solid fiberglass with aluminum plates for things like winches, sheet stopers, etc., which is as it should be.To For a manufacturer to say they are a "production boat" to avoid appropriate use of epoxy is a cop-out. I just can't believe it would cost that much. Once epoxy is mixed the shelf life can be extended greatly by puting it in a freezer so they could mix up a batch and draft out of it during the course of several days.The Owners Manual for my boat is totally silent with regard to any resealing requirements but has information for many other things.Gotta leave now and put on my flak jacket!
