Interesting problem. The last few times I have gone out, when I shut down, I have a very hot electrical smell permeating the cabin. No obvious melting wires, or smoke, and I have scoured the boat. Anyway, I have narrowed it down to the alternator (took it off, and smelled it up close - THERE is the smell). I am taking the alternator to the shop today to have it checked, but here are my two questions:
- The belt is appropriately adjusted, the voltage was 14+ on the dash meter, and the bearings are smooth and quiet, so why the overheating?
- Why would there be a wire with a slow blow fuse from the output (+) pole to the ground pole on the alternator? This makes NO sense to me, but has been there since I bought the boat.
BTW - As I was removing the alternator, this fuse wire came apart mechanically (may have BEEN apart before I started). This wire REALLY puzzles me.
The previous owner installed this alternator (BALMAR 912-75D - Dual pole with a jumper bar- one output) and a 3 stage regulator (In Charge). Vintage is around 2001, I believe. Specified output is 90 amps. (2) 4D batteries were new last year. Wiring is stock config from Catalina (I know, I know), except the charge wire is #2AWG to the starter.
Any advice or guidance you can provide is much appreciated.
Jon Freeman
Catalina 310 "Summer Sojourn"
Tacoma, WA
Jon Freeman
Tacoma, WA
