Balmar external regulator not lighting; no apparent alternator output
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
This morning I started the diesel engine but my Balmar ARS-5 regulator did not come on. It worked last night but not this morning:doh:. The tachometer did not work, nor did the fuel gauge meter. No engine hours were recorded. Lately I've had a problem with the ignition switch not springing back fully after starting. How are all these symptoms related? Might I need a new regulator and switch, etc.
KG
The ARS needs a power source, if that source is through the ignition switch, then checking that circuit would be a good start. Check the ARS manual for the recommended wiring.
I doubt you need a new regulator, a new switch is a good possibility, check all the connections first.
Likes: Kings Gambit
From your description of the symptoms, I would start with the wiring. Specifically the start switch. Look for loose connections, burnt wires, fuses etc. Your DVM is your friend. :biggrin:
Now if you would prefer a new regulator, then often dashing out and buying one will, when attempting to install it, disclose the wiring issue. It is a two fur resolution. You get your new bling and discover the electrical issue.
Chasing electrical issues with a smile requires a certain mental derangement syndrome.
Likes: Timm R Oday25
Jul 27, 2011
5,203
Thanks for the replies. I installed the Balmar alternator and external regulator in 2017 which is about 1000 engine hr ago now. The ignition switch is the original one, making it 25 yr old. It gets wet a lot (outside) as it is near the cockpit sole. Water deposit might be impeding the spring-back action. I’ll check out the connections but in the meanwhile I’ll be getting a new switch regardless. If the switch does not spring back, the starter bendix remains engaged w/the flywheel, I believe.
KG, just jumper the power (not start) terminals in the back of the switch to see if the ARS turns on. Dave and Don are right.
Jul 27, 2011
5,203
Thanks Stu. I've discovered that the switch was not still "on" after the engine started. Diesel is running now and all appears well, but the switch needs to be replaced. It's acting, as someone said, "flakely." But some operator error also occurred. This happened yesterday as we were preparing to leave Emerald Bay an hour after our checkout time off the mooring. I had already fiddled with it but did not come up with the correct remedy :doh:. So, we shut down the fridge and other electrical consumers except nav instruments. Hooked up the solar panels, and sailed home. Nice afternoon sail. Could have done that anyway!
