I have been messing around with an ARS lll regulator that is powering two house banks of paired 6 volt golf cart batteries and an isolated starting battery through a 100 amp Balmar alt. Anyhow, the first issue was that the sense wire was hooked to the starting battery. Obvious fix. After that, when tested, on the initial charge, the output was about 14 volts without loading. It then went to about 13.5. Recently, with a 60% discharged bank (11.0 volts) it went into float at somewhere between 12.5 and 13.0 volts. Seems well shy of 13.8. These things are supposed to be pre-set for gel, so I would expect something greater. Anyone care to share their experience? Also, from a 11.5 to a 12.5 charge, it takes about 45 minutes of run time at 1500 RPM with 10 amps drawing from the refrig & freezer. Sound about right? (FYI: Yanmar guy recommended 2000 RPM for battery charging as much as they don't like the practice to start with.) Rick D.
